DI-718Bx "Save Default Setup" and "Open Reference File" Calibration Settings Error
View pdf View the pdf
On this Page
Symptoms
Cause
Resolution
   Delete TPDATAQ.ini and re-install WinDaq software
Applies To
Symptoms
After selecting Save Default Setup from the File pull-down menu and restarting WinDaq, calibration settings are not retained.
   Selecting Open Reference File from the File pull-down menu and choosing a previously recorded data file does not transfer calibration settings into WinDaq.
Cause
Software Bug
Resolution
  1. Locate TPDATAQ.INI in the WINDOWS directory, and delete it.
  2. Download the latest installation from: www.dataq.com/support/downloads/new710.exe.
  3. Run the new installation software that you just downloaded, installing the application over top of the existing installation.
The software should now operate properly.
Applies To
All DI-718Bx Products.
